Getting 'null' error while adding Mobility Controller (Add device)
Hope somebody can help me with this
Getting 'null' error while adding Mobility Controller aruba3200 (Add device) to CPPM 5.2
I feel in every field with what written in an integration guide and when I click add it holds quite long and then writes in red 'null'
Any ideas where I can look for a system log or other stuff that could help me to define the problem?
or maybe there is another integration guide to give me an idea what I did wrong in previous steps?
Thank you in advance.
Re: Getting 'null' error while adding Mobility Controller (Add device)
Olena,
That should not happen.  You should probably open a support case...
Occasional Contributor I
There is a pathch "ClearPass 6.1 Cumulative patch 2" on the support site that fixes this issue.
