Frequent Contributor II
Guest Extend Expiration not applying from Sponsor Form
I'm not sure when this issue started, but the it seems to have started after upgrading to Clearpass 6.6.8
Whenever a sponsor approves guest access, I have extended expiration entries set for them to choose from if the default expiration of 1 day is not good enough. They are able to select the extedned expiration dates, but they are not applying to the guest account. I've tried removing the +0d entry, but I'm not sure why this has stopped working. Any thoughts?
Re: Guest Extend Expiration not applying from Sponsor Form
After some mroe self testing, I found that "m" is not allowed in the syntax here. Hour "h", Day "d", and Year "y", are the only acceptable formats.
I've now replaced +1m with +30d
