Guest Registration with Extreme Wireless Controller
Hi all,
So I have the captive portal redirect working, registration is good, but when we click Login after, it is failing. Extreme is not a preset option for the Login part, what settings would I need to have? Does someone have this working they could provide info/screenshots?
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Re: Guest Registration with Extreme Wireless Controller
UPDATE -
Worked with ClearPass TAC engineer, was unable to identify the correct settings. Recommended reaching out to Extreme TAC to try and collect the info. If anyone has a working example, it would be really helpful.
Thanks.
Michael Haring
Hi Michael
Did you ever get this working?
Andrew
Unfortunately I don't think we did. We were close, but there just seemed to be something odd happening with the authentication being submitted back to the controller. If we set it to controller initiated, it wouldn't work, if we set it to server-initiated, it would sort of work. Never fully worked though.
Michael Haring
Senior Network Engineer
Comm Solutions Company
Direct: (610) 246-6037
Office: (610) 889-1280 x176
Email: mharing@commsolutions.com
Sent from Outlook Web App
Michael Haring
