Frequent Contributor I
Guest Self-Registration with AND without sponsorship confirmation
Hi again,
Is there currently a way to setup guest self-registration so that guests can either choose a role that requires no sponsorship confirmation (e.g. I'll limit the bandwidth/expiration etc..) or a role that does require sponsorship confirmation?
I'm comfortable with the choice of roles and enabling this functionality, but I'm not sure how you could implement (if at all) the sponsorship confirmation element?
Thanks!
Any amount of Kudos will be greatly appreciated!!!
Moderator
Re: Guest Self-Registration with AND without sponsorship confirmation
One quick and easy way to address this requirement would be to host an initial landing page that gace the guest the option to select the basic bandwidth limited service vs the full access with sponsor approval. You could then simply link to the two indivdual self registration pgaes configured with the appropriate roles and sponsor approval settings.
Hope this helps
Cam.
Thought that might be the answer, thanks Cam.
