Contributor I
Guest Sponsorship Validity Check Question
Hi all,
I have recently implemented a sponsor based guest sponsorship system. The only disadvantage is that I have been asked to use the non-authenticated sponsor email confirmation instead of making the sponsors log in.
I have restricted the sponsor emails so that they must be from our domain, however, students have the same domain. I would like to be able to restrict them from being able to sponsor themselves.
All student email addresses are in the format of 'aabbbbbb55@domain.com' (first 2 initials, up to 6 of last name, and two digits)
Is there a way to restrict this format via the validity checker?
--Ben
Re: Guest Sponsorship Validity Check Question
Just change the doman from gmail.com to your domain:
^[A-Za-z]+[0-9]{2}@gmail.com
Insert it as below in the sponsor email field (assuming you're using that one) and set the validator to IsRegexMatch.
Edit: removed the 0-9 from the first part of the regex.
Cheers
James
Contributor I
Changing the validator to regex would drop my current domain restrictions correct?
If so, can I add multiple regex statements?
A single regex would work.
E.g. the following regex will match any number of a-z characters @ gmail.com anbd ggg.com.
^[A-Za-z]*@(([g][m][a][i][l])|([g][g][g])).com
I would recommend checking out the following regex site to learn how to use regex expressions. https://regex101.com/
Cheers
James
