Guest WiFi
Is it possible to check mobile devices if they have installed specific Application before allowing them to connect to guest WiFi?  and if they will not have this Application force them to download it before granting access ?
BR
Re: Guest WiFi
No, this is not possible.
Tim Cappalli | Aruba Security
Re: Guest WiFi
Is there any solution to accomplish this task?
i just need to check if user has installed specific Application.
Re: Guest WiFi
No. This is an EMM function.
