Regular Contributor I
Guest Wireless only Accept Use Policy using Clearpass?
I'd like to keep forwarding our guests through clearpass so that I can continue having an option for users to login using credentials through RADIUS, but I'd like it so that Guests can just click accept and get x amount of time of access before having to accept the Use Policy again. Is there a way to make this happen?
I came across this link, but it's controller specific and doesn't involve adding a section for Guests to click a link to log in with their RADIUS account.
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154
Re: Guest Wireless only Accept Use Policy using Clearpass?
Yes,
You can create a page that has a choice of who the users are and they would click the link or put a login page with a link to the guests click to accept.
Just be forward you are going to have to walk through quite a few steps to setup a the accept terms so if your not familiar with setting one up your best bet is to work with a partner or professional service.
Thank You,
Troy
Really I suppose the question is, is there a guide around for setting up a page that just makes a guest user accept the use policy? I can add a link to a webpage, so that really isn't the hard part.
I just know that clearpass is generally reliant on users logging in, but I don't want guests to have a username/password.
Does Clearpass have the capability of just having a user accept the TOS?
I can't seem to figure a way for it to not check agains a user database.
I guess the other question would be how can I get the mac to populate the user database by just click accept.
My other thought, I could probably setup the captive portal on my controller which has instructions for doing the captive portal with just an accept. Then I can add a link that forwards internal users to a login page to use their credentials to log in? Would that work?
Thanks that hasn't shown up in any of my searchs. It appears on first look to be just the thing I am looking for!
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/single-click-guest-SSID/m-p/118489/highlight/true#M7857
Thank You,
Troy
