Contributor I
Guest account expire after first use
Im looking at setting up the guest accounts with a standard password but perhaps have different usernames (token would be better) . I would like these accounts to expire after 8 hours from the first time they are used.
The idea is that they username and password are printed out on cards and handed out to guests to use.
Is this at all possible? Are there any tutorials on this?
Contributor I
Re: Guest account expire after first use
Never mind, i found where to set it up in the documentation.
Its refered to as access codes and you set it to account expiration for like 2 years, then you set the account lifetime to something like 8 hours, which will then take effect after the first login :)
