Guest wireless access is dropping out after 4 hours.
  • 1.  Guest wireless access is dropping out after 4 hours.
    Posted Apr 10, 2014 06:40 AM
    Controller:                 6000
    Version:                     6.1.3.9
    In short
    After authentication via the guest portal, the guest wireless disconnects after 4 hours of use, the guest session is not idle.
    I'm guessing that this is a timeout option somewhere, but i'm unable to find it, any pointers in the right direction would be appreciated.
    Al.
  • 2.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Apr 10, 2014 07:59 AM
    Are you using the controller internal captive portal ?
    Check the following :
    (CONTROLLER) #show aaa timers
    Global User idle timeout = 300 seconds
    Auth Server dead time = 10 minutes
    Logon user lifetime = 5 minutes
    User Interim stats frequency = 600 seconds
    (CONTROLLER) #show wlan ssid-profile GUESS-SSID
    Parameter Value
    SSID enable Enabled
    ESSID guest_ssid
    Encryption wpa2-aes
    Enable Management Frame Protection Disabled
    Require Management Frame Protection Disabled
    DTIM Interval 1 beacon periods
    802.11a Basic Rates 6 12 24
    802.11a Transmit Rates 6 9 12 18 24 36 48 54
    802.11g Basic Rates 1 2
    802.11g Transmit Rates 1 2 5 6 9 11 12 18 24 36 48 54
    Station Ageout Time 1000 sec
  • 3.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Apr 10, 2014 08:03 AM
    HI,
    Thank you for the response and yes, we are using the controller captive portal.
    I will check the ssid profile as suggested and post my findings.
  • 4.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Apr 10, 2014 08:32 AM
    In the Guest user role, make sure that you do not have a reauthentication interval configured for 4 hours...
  • 5.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Apr 10, 2014 09:59 AM
    Firstly - Thank you for the responses.
    To confirm, the issue was the Re-authentication Interval.
    For reference this was found in...
    Configuration > User Roles > 'Role' > RE-authntication Interval
  • 6.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Jan 03, 2018 07:35 PM
    My version is 6.4.4.  Want to make sure I'm looking at the right setting. I'm having a similar issue. I'm looking at Security/Access Control/User Roles.  Is that correct?
  • 7.  RE: Guest wireless access is dropping out after 4 hours.
    Posted Jan 04, 2018 05:44 AM
    Correct.  The Reauthentication interval should not be configured or just 0.
