http://imgur.com/a/2DKlm
I have a need to replicate the 'Session-Check' -> 'Active-Session-Count' -> 'GuestUser:simultaneous_use' template enforcement profile provided for Guest, for an external SQL auth DB.
Use case is guest user credentials can only auth/access guest using 3 different endpoints. If greater than 3, then disconnect session.
I need to summate username's used for authentication against a variable. The rest of the logic I can do.
Some ideas ?
Each time guest is accessed [endpoint repository] is updated and username attribute added to the endpoint listing.
Is there anyway I can leverage this information ?
