- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Guests connect but disconnect soon after
11-19-2013 08:35 AM
I'm hoping someone can help with this.
I have a Dell Powerconnect W-620 controller running Aruba 6.1.3.7.
I also have two AP's associated to this controller.
I have already configured a network for LAN connection using EAP/RADIUS and now i'm trying to create a Guest SSID.
I have followed what i thought was correct below but it seems the clients (Win7 Laptop and Android Phone) connect, get an IP from the Guest DHCP pool and then disconnect a few seconds afterward.
Subsequent attempts to connect nearly always fail straight away without getting an IP.
I have ran traces using NetMon on the laptop and not every time there are DHCP requests and you can see the IP given by the Guest VLAN IP to the laptop. If you run a quick 'ipconfig' it gets the IP ok but soon disconnects with no event logs.
I have only added the pre-authentication role policies below as it doesn't hold its IP long enough to logon to the captive portal.
Details:
Guest VLAN created -
ID=200 - IP 20.20.20.1 /24 - Not associated to any port
Enabled src-NAT for this VLAN
Inter-VLAN routing enabled
DHCP -
Enabled
Guest_Pool1 -
Default Router - 20.20.20.1
Network - 20.20.20.0 /24
Range - 20.20.20.6 - 20.20.20.254
NAT Pools -
dymanic-srcnat 0.0.0.0 - 0.0.0.0 - 0.0.0.0 for everything
IP Routes -
default gateway - 10.0.0.6 (IP of Firewall)
No other routes
Roles-
Role - LM-Guest-guest-logon (pre authentication/captive portal)
Policies-
captiveportal
source user Dest controller Service svc-https Action dst-nat 8081
source user Dest any Service svc-http Action dst-nat 8080
source user Dest any Service svc-https Action dst-nat 8081
source user Dest any Service svc-http-proxy1 Action dst-nat 8088
source user Dest any Service svc-http-proxy2 Action dst-nat 8088
source user Dest any Service svc-http-proxy3 Action dst-nat 8088
Guest-Logon-Access
source any Dest any Service svc-dhcp Action permit
source any Dest Public-DNS Service svc-dns Action src-nat pool dymanic-srcnat (Public-DNS contains list of external DNS servers)
Block-Internal-Networks
source user Dest Internal-Networks Service any Action deny ( Internal Networks lists IP ranges for internal networks)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Guests connect but disconnect soon after
11-19-2013 08:39 AM
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:42 AM
Doesn't look like it.
From what i can gather (since the connection only lasts a few seconds) it gets the DNS servers that i have assigned but it can't resolve www.google.com when pinging during its time of having the IP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:43 AM
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:46 AM
Just going through an Aruba doc, albeit a little old but it gave me the fundamentals to set this up.
I have no doubt there is something just configured incorrectly.
Shall i just permit DNS ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:47 AM
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:53 AM
Ok.
I permitted DNS and it still dodn't work.
Rule for Guest-Logon-Access
any any svc-dhcp permit
any public-dns svc-dns permit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 08:54 AM
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 09:01 AM
The client gets an IP 20.20.20.253
This IP is not routable to the internet
The VLAN is set directly on the controller.
The controller is connected to a switch stack which doesn't have this VLAN 200 added to the trunk (not that i though this was necessary as i understood it used the address of the controller as its NAT)
This switch then connects to a Firewall and then out to the internet.
The default gateway on the controller is that of the Internal IP of the Firewall.
I can understand if the client kept its IP but couldn't get to the Captive Portal but the clients are dropping the wireless connection within 10 seconds....slightly annoying me :-)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
11-19-2013 09:23 AM
You need to allow DHCP on your captive portal role too ?
Make sure you have attached the captive portal profile to that role too ?
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
