Contributor II
HP UWW integration question
Hi all,
Another ClearPass question, in hope that someone has done HP Unified/CPPM integration.
In integration guide Captive Portal page is being accessible only on isolated (serving only CP) VLAN. Only after successful authentication, device is placed in VLAN with internet access.
My question is, if there is a way of avoiding "CP only VLAN" design, and follow standard Aruba setup where client device gets IP address, access CP, and authenticate on one VLAN? Thanks in advance.
AlanFord
Kind regards,
AlanFord
Re: HP UWW integration question
Unfortunately, no. This is a limitation of the UWW platform.
Tim Cappalli | Aruba Security
Contributor II
Much appreciated Tim, helpful as always!
Cheers,
Alan
Kind regards,
AlanFord
