Contributor I
Has anyone know about How does to provisioning Android device?
Hi All,
   I tested MDAC with ClearPass( amigopod) which deploy client certificate to IPAD, Iphone and work fine. Then I tried to provisioning Android device but after I passed authentication the Amigopod redirected me to me to page which show token key . I don't know how to do next to get work with android device?
please advice me.
thanks in advance.
Contributor I
Re: Has anyone know about How does to provisioning Android device?
Please see capture below
Moderator
Android provisioning is supported in the 3.9 release of Amigopod. Please contact support to ensure your subscription id has been updated to the latest version.
Contributor I
Hi Cam,
Thanks for you reply. If i need to provisioning my win7 computer  and I got that page like previous post.
how should i do? Because I saw only token key but I don't know how to use token key?
Moderator
You will need Amigopod 3.9 for provisioning of Android, Windows XP, Vista, Windows 7, Mac OS 10.5, 10.6, 10.7 and continued support for Apple iOS devices.
