Help! IP Pooling Cisco Anyconnect CPPM
Hi Airheads,
First of all i'm quite new to the community and new to Aruba related products.
We started off in december with a WiFi pilot with the current setup:
Controller 7210 (version: 6.4.2.2)
AirWave
CPPM (version: 6.4.2.68288)
Together with our 3rd party network team we're trying to do all authentication for our switches and vpn via CPPM. The authentication part was easy to setup, however we are also trying to setup assigning IP address via CPPM. Is this possible? What would be to best way to achieve this?
Client > AnyConnect > CPPM (Authentication + IP) > AnyConnect > Client
Thanks in advance
Alex
Re: Help! IP Pooling Cisco Anyconnect CPPM
Where would you be setting the IP assignment? From a database, not DHCP?
Tim Cappalli | Aruba Security
Hi
I'm trying to see which options i have, DHCP server, Database, Controller etc.. Any way is fine, just need to know how i assign the ip in CPPM
The answer is really going to depend on what you want to do. Do you want static addressing or DHCP?
If you're going to use a DHCP server, ClearPass would not be involved.
If you're using Active Directory, IP addresses can be assigned for each user and ClearPass can send the IP back via a RADIUS VSA.
Thanks, saw in 1 of your replies in a other thread a detailed explanation. (http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Cisco-ASA-VPN-Returning-IETF-Framed-IP-Address/m-p/219170#M16973)
Thanks for all the quick replies!
