Super Contributor I
Help interpreting clearpass logs
Does anyone know how to interpret clearpass logs? For instance, can anyone explain the "h" and "c" values?
2013-09-20 09:01:51,082[RequestHandler-1-0x7f2c6c3c1700 h=95241389 c=R005105e2-06-523c473f] WARN REC.EvaluatorCtx - Prerequisites set is empty, not populating the Request Map
Overall, I'm observing there are a TON of clearpass logs spitting out by default. Yes, I can trim them to errors from warnings, etc., but I'd like to understand the logs more before getting rid of some.
Ryan Holland, ACDX #1 ACMX #1
The Ohio State University
