Contributor I
Help setting ClearPass as External CaptivePortal for Guest users
Hi, I'am trying to setup Aruba Virtual Controller and ClearPass Guest for my new Guest-Wifi, but i cant get to work, does Aruba have som documentation setting up IAP with GuestSSID and external CaptivePortal?
Best regards
Niklas
Re: Help setting ClearPass as External CaptivePortal for Guest users
https://ase.arubanetworks.com/
Thank You,
Troy
Contributor I
Great thanks, I've got that part :)
Do you know if there is any documentation on the Clearpass?
