Frequent Contributor I
Help with Quarantine Enforcement Profile
I am attempting to write an Enforcement Profile that will quarantine a user to a "Dead" vlan on a Cisco switch.  I want to be able to manually change the user's switch port to a dead vlan with a CoA Status change from Access Tracker.
Here is my attempt at writing the profile.  When applying the CoA to the user, CPPM shows the CoA request was successful, but it doesn't change the vlan on the switch.  What am I missing?
Re: Help with Quarantine Enforcement Profile
Are you using Onguard ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
You need to send a regular VLAN enforcement profile
Thank you
Victor Fabian
Victor, I am not using OnGuard.
I tried making a VLAN Enforcement profile, but the problem is then that profile is not accessible via the Change Status from within Access Tracker.
See below.
I guess you don't want to apply a dynamic enforcement profile instead you want to do it manually ?
Thank you
Victor Fabian
Correct.  I want a way from within Access Tracker to be able to manually quarantine a user off the network, by using the Change Status button and select an appropriate CoA profile to put them in another VLAN.
Moderator
Did you enable CoA whe you added the NAD?
Best Regards
-d
ClearPass Product Manager
Yes, CoA is enabled on the switch.
aaa server radius dynamic-author
 client 1.1.1.1 server-key 7 <key>
 port 3799
 auth-type all
Moderator
and you enabled it on the NAD definition within CPPM?
No firewall, blocking 3799 between CPPM and the switch?
Best Regards
-d
Danny,
Yes is enabled in CPPM under the device profile.  No firewalls between the NAD and CPPM.
Do you know what the Enforcement Policy should look like to use it under the the Change Status button?
