Hi,how would I integrate Cyberoam UTM with Aruba for SSO Cyberoam provides API support.
Hi Team,
I would like to integarate Cyberoam UTM with Aruba networks for SSO. Cyberoam supports API. Can you explain the way for integarating Aruba with Cyberoam UTM?
Re: Hi,how would I integrate Cyberoam UTM with Aruba for SSO Cyberoam provides API support.
What are you looking for? I dont understand your question.
Are you looking for CPPM to send user information to the firewall or what?
Thank You,
Troy
Hi Troy,
Thanks for your repsonse and applogies for the delay.
Yes, I would like to send all user information to Cyberoam firewall for SSO similar to Palo Alto. Palo Alto provides SSO with Aruba with API integration. I would like to impletement similar SSO with Cyberoam.
Please, help me for the same.
Keyur Shah
Occasional Contributor I
Hi Troy, I've the same problem but with Fortigate UTM with FortiOS 5.2 (latest). The Fortigate UTM is also a integrated controller for wi-fi FortiAP. In the new FortiOs release the vendor support external captive portal for Guest or User authentication, I would like to use Clearpass to manage guest access instead of Fortinet integrated solution for many reason...
The problem is that Fortinet acept external authenticator if their send it back the information's login parameter in a concatenated http POST submit. (I attach to this post an Fortinet internal flow). I'm trying to customize Clearpass Guest Registration portal in NAS Vendor Login but all the test I'v made was unsuccesfull....
It's possible that ClearPass supports Fortinet in vendor settings ? or do you know how I have to configure NAS Login in this case ??
Sorry for my bad english.....
thank you in advance
Toni
Ive asked engineering to take a look at it.
Thank You,
Troy
Hi, I want to implement the same thing. Did you figure out the way?
Moderator
@rehamt - Are you looking for the FortiNet integration or the Cyberoam integration?
Best Regards
-d
ClearPass Product Manager
