High Capacity Guest mode
Hello
As far i read i can enable this to double the amount of policy manager license if i purshace a 5k policy manger then i would get a 10k policy manager server.(i would need to buy all the guest license needed in this case)
My question is
If i want to integrate it with opera will this work? i mean the integration with opera of the  clearpass guest is still working is not disabled?
I need to kno this because we would like to enable the high capacity guest mode but we need to suppport the integration with opera(i didnt read it disable it but still i ask)
I also guess the mac cache also works right?
cheers
Carlos
Alternetworks Corp
Moderator
Re: High Capacity Guest mode
No issues with HCG Mode. Normal HCG limitations apply.
By default PMS use standard guest licensing.
We are now GA with Micros and we should appear on their certified list this month. No additional details regarding that module, that still needs to be purchased by the customer/partner.
Best Regards
-d
ClearPass Product Manager
Hello Danny
So you dont need to buy anything on fidelos part to make opera work with clearpass?
maybe a module in opera ?  or no purshase of anything is needed ?
They would like to integrate this so they can charge the client a fee of internet.
Alternetworks Corp
Moderator
You still need to purchase the fidelios component.
Best Regards
-d
Regular Contributor I
Does mac-caching work with High-capacity-guest enabled?
Yes
Tim Cappalli | Aruba Security TME
