How Guest will receive Sponsor Approval email if Guest doesn't have Internet
Hi
I am designing guest access scenario and some question raised up;
The guest will do self-registration and wait for a sponsor approval, so he must wait for an approval email sent from CPPM which will contain the created guest account.
But how the guest will recieve this email as in this stage he doenst have an internet access!
Mahmoud
Mahmoud
Re: How Guest will receive Sponsor Approval email if Guest doesn't have Internet
After a guest requests approval, there is an HTML page that refreshes every 20 seconds to tell the guest that they are approved. At the same time, an email is sent to the guest, that can be received on a mobile phone.
The sponsor approval email goes to the guest's sponsor. The guest should not need it.
Tim Cappalli | Aruba Security
So the guest will recieve the reciept page which contains his account credentials on the same login-page/registration-page, and this page will refresh every 20s, right?
So in this case he must keep the same page open, and else he will not receive the reply, right?
Mahmoud
The approval can also be sent via email simultaneously which we assume that a mobile device can receive.
