Occasional Contributor I
How does Clearpass check which device is which?
Hello guys and girls,
I was trying to figure out how to check in clearpass how it know it's for example a mobile, or a laptop.
This is because I thought I read somewhere (can't remember where), that I needed to configure on remote switches where AP's are connected to, a ip helper address to point to the clearpass.
Otherwise it would not know if it's a laptop or mobile.
Could someone help me please?
Thanks in advance for your help!
Re: How does Clearpass check which device is which?
Please go to
 https://<ip address of clearpass server>/tipshelp/html/en/index.htm#CPPM_UserGuide/Profiling.htm
and
https://<ip address of clearpass server>/tipshelp/html/en/index.htm#CPPM_UserGuide/EndpointProfiles.html
Also, search for profiler in the online help for a full explanation.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/5817/1/ClearPassProfileTechNote.pdf
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Moderator
Please look at a newer TechNote I published on this subject.
ClearPass Profiling TechNote V1.1.pdf
Best Regards
-d
ClearPass Product Manager
Super Contributor I
You can also go to the following in Clearpass:
Configuration > Identity > Endpoints
to see how those devices are currently being classified within the system.
-Mike
