How does Cluster-wide Parameters effecting CPPM reports/logs? - please advise
Hi Guys,
I need to collect reports from insight each month of guest users per ssid.
I would like to know if i set the Cluster-Wide parameters to delete info every day - is it effecting my reports? please advise.
Thanks in advance.
Me
Re: How does Cluster-wide Parameters effecting CPPM reports/logs? - please advise
No that is just for the local storage for access tracker and endpoints. All data will get pushed to insight. There is a setting in Insight on how many days of data that you will store under the administrations tab.
Thank You,
Troy
A. Thanks.Found it
B.
Database Retention - for how long to keep the databse records? of all the cppm users/guest info?
Report Retention - for how long to keep created reports?
Correct x2
Thank You,
Troy
