Frequent Contributor II
How i design ClearPass solution with onboard
If number of authenticated device is more 25,000 devices in HQ. Within HQ is separated 3 buildings. How i desire number of Cleapass hardware ?
User behaviour,  they must move between each building but I concerd about BYOD (onboard) solution
If i place clearpass on each building. User A registered own device on ClearPass at building1 and User A walk to building2. Must User A register own device again ? because I think ClearPass database is seperated.
How I design and solve this problem
Re: How i design ClearPass solution with onboard
ClearPass is clustered. The same data will exist on all 3 boxes and users will be able to authenticate without issue.
You should work with your ClearPass partner on a design.
Sent from Nine
Tim Cappalli | Aruba Security
And when I want to manage Clearpass, I must access clearpass each box or I can manage all clearpass via 1 ip address
It would be managed through the publisher, yes.
Sent from Nine
