Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Aruba Documentation Portal
Aruba Support Knowledge Base
Community Learning
News
ACEX Hall of Fame
MVP Overview
Tech Corners
Search
Community Home
Discussion
Topic Thread
Community Home
Discussion
60K
Library
1.9K
Events
0
Members
2.1K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
How redirect to original URL work in captive portal
Jump to
1.
0
Kudos
keya_n
Posted Apr 19, 2016 03:31 AM
Reply Privately
Options Dropdown
Hi All,
I would like to know how redirect to original URL that the user tried to access is redirected in captive portal.
2.
RE: How redirect to original URL work in captive portal
0
Kudos
Victor Fabian
Posted Apr 19, 2016 06:05 AM
Reply Privately
Options Dropdown
Are you using controller or ClearPass captive portal ?
Sent from Outlook for iPhone
3.
0
Kudos
keya_n
Posted Apr 19, 2016 09:08 AM
Reply Privately
Options Dropdown
Hi Victor,
Splash is hosted on clearpass.
Karthikeyan
4.
0
Kudos
Victor Fabian
Posted Apr 19, 2016 09:28 AM
Reply Privately
Options Dropdown
By Default that should work unless you either are forcing the user to be redirected to a particular page under the Layer 3 Captive Portal Profile (Controller) or Under the Guest Page (ClearPass Guest Module)
5.
0
Kudos
keya_n
Posted Apr 19, 2016 09:39 AM
Reply Privately
Options Dropdown
Is it the controller or clearpass that does the redirect to original URL after HTTP Post?
6.
0
Kudos
Victor Fabian
Posted Apr 19, 2016 09:53 AM
Reply Privately
Options Dropdown
The controller
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2024 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
