Frequent Contributor I
How to Build Policy Simulation for Service Categorization
I am attampting to use the Policy Simulation to build a Serivce Categorization.  Attached is my simulation, but it doesn't seem to match a valid service I have running. I am attaching the screenshot and policy simulation file.
Are there any docs or examples of how to build a simulation and test it against a service?
Re: How to Build Policy Simulation for Service Categorization
Can you confirm that some of those attributes are present as service rules in an active service?
Tim Cappalli | Aruba Security
Here is the attached simulation file.
Tim,
I am learning ClearPass, so be gentle as I am likely missing something obvious.  Total NOOB here. I took a working Wired 802.1x service and looked in Access Tracker to see a valid request that came in and tried to replicate those Radius reqeust attributes in the policy simulation.  Is that a valid way to go about building a simulation?  Attached is the Wired service I built the policy from.
Hm. The service rules look correct.
Are you working with an Aruba partner? It looks like this is a proof of concept build.
I am working with Aruba directly as we are testing the product and trying to get familiar with its capabilities.  The Policy Simulation was intriguing if I can get it working.
Can you try creating a simulation with just the basics:
NAS Type: Generic
Authentication outer method PEAP
Username
Password
IETF NAS-Port-Type 15
Thanks for your help Tim.  Not sure I am doing this right.  I have attached the simulation I built for your review.
Couple of Questions if I may:
1.  Does the order of attributes in the RADIUS request matter?
2.  Where is NAS Type Generic?  I didn't see where to select that attribute?
You must add a connection Type in the test.
Mark,
I updated my lab on your test. You can see the results there. I aslo trigger my services based on NAS IP so you also need to add the IP of the switch.
Thank You,
Troy
Thanks Troy.  That was the missing piece.
