Frequent Contributor I
How to Disable wireless interface when ethernet is up?
Hi Airheads Experts,
I would like to ask you what is the best practise if I would like to disable wireless interface when ethernet is up and enable when ethernet is down. I find all of the potential solutions. With script on the client, Onguard if it is possible, or with ClearPass NAC rule (deny rule) and whatever.
Thank you in advance for your reply!
Br.,
Zs
MVP
Re: How to Disable wireless interface when ethernet is up?
[ Edited ]
OnGuard + CPPM rules ofcourse.
the OnGuard will popup a demand from to user to enable or disable needed interface or it will not let the user pass the healthcheck
read here:
http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/21122/1/OnGuard%20config%20Tech%20Note%20v1.pdf
MVP
http://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/Content/CPPM_UserGuide/Admin/Onguard_settings.html
Thank you, it was useful! But we are looking for a solution that switch the interfaces automatically.
Do you have any idea for this? Any third party or ecosystem partners or recommended programs and solutions?
Br.,
Zs
Is there any update on this, or any idea?
Thank you!
