Contributor II
How to Write an ACL
Hi I have the next stage.
On the cisco side :
Action     Source ip/mask                          Source ip/mask    Protocol     Source Port       Dst Port
permit       udp             any                      2100
On Aruba side:
Source                                                              Destination           Protocol     Port        Action
network        any                         udp            2100      permit
I´m using the minport 2100 and maxport 2100 option.
But I need use the source "any" and dest 2100 option on the rules editor to replicate exactly the same rule from cisco. And I don´t know how to put that "any" the editor only let me use from 0-65535 range.
How could I reach this. ?
Thanks in advance.
Re: How to Write an ACL
The source port is assumed to be "any".  Your rule can be written like this:
network any udp 2100 2100 permit
**The min/max port should be the same if you want a single port destination.  The source port of that request is asssumed to be "any"
It can also be achieved by using aliases/network destinations:
netdestination "network-name"
alias "network-name" any udp 2100 2100 permit
Contributor II
Thank you.
