How to activate Guest accounts after first login in clearpass guest?
  • 1.  How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 23, 2014 05:42 AM
    how ro activate account after first login not after creation
  • 2.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 23, 2014 06:18 AM
    For admin..
    "Account activation" = Now
    "Account expiration" select "Account expires after...". This triggers the field "Expires after".
    "Expires after" = your choice.
    The account expiration timer will then start after first authentication.
  • 3.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 24, 2014 04:48 PM
    Thanks I know that I mean I need to print many scratch cards each 1 is one hour so I need account to start counting the hour after the first login not after creating it.
  • 4.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 25, 2014 01:37 AM
    Yes, and that is solved if you do what I described. The point is that you want it to last x hours from first login, regardless of when that login happens.
  • 5.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 25, 2014 09:13 AM
    I followed the same as you said but thsi account expired without any logins as you can see in attached
  • 6.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 25, 2014 09:23 AM
    Yes, sorry about sending you off in the wrong direction. I was too quick in my original answer..
    If you look at the Create Multiple default form you have a field there called "Account Lifetime" which is what you need.
    Put the Account Expiration to "Do not expire" and input something like 8 hours in the "Account Lifetime" field.
     Editied: If you want to have this field in another form, the name of it is "expire_postlogin". By default this field is not part of the create_single user form.
  • 7.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 25, 2014 12:38 PM
    Thank you so much one more thing can i do it with self register Guests,
    like guest came and register how to make it ? and where I will find the Post login ?
  • 8.  RE: How to activate Guest accounts after first login in clearpass guest?
    Posted Nov 26, 2014 04:40 AM
    I can't recommend that for self-registration. Just activate it instantly and allow them to re-register when the time is up.
    Only scenarios where it's useful is for admins to pre-register a bunch of scratch-cards or conference attendees or something like that..
