Frequent Contributor I
How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
We have two controlers Wifi and two differents domain AD (with no approbation), and one Clearpass, the EAP termination is not on the controler.
With MSCHAPv2, is it possible to authenticate* users via 2 differents AD domains with only one CPPM ?
* Not only for used for user lookup and attribute fetching.
Regards
Yann
Re: How to authenticate users in MSCHAP2 via 2 differents AD domains with only one CPPM ?
Yes. You can join multiple domains and add multiple AD auth sources in the service.
Thank You,
Troy
Hi Tarnold,
I have all ready add my two AD in auth sources.
I tried to do this, but it's doesn't work, i have this error message when i want to authenticate one AD user on my wifi 802.1x.
RADIUS
MSCHAP: AD status:Reading winbind reply failed! (0xc0000001)
MSCHAP: Authentication failed
EAP-MSCHAPv2: User authentication failure
Regards
Yann
Make sure you joined CPPM to the domain and the read account in the auth sources has sufficient privileges.
Thank You,
Troy
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/CPPM-AD-Authentication-Error-Message-Reading-windind-reply/td-p/139513
Thank You,
Troy
Hi Tarnold,
Thanks you for your answer, but it's no possible to join two differents domain with only one Clearpass.
Have you another way ?
Regards
Yann
Yes you can.
Here you can see that Im joined to 3 domains that do not have any trust between them.
Thank You,
Troy
it's true, I had not seen !!
Thanks Tarnold !
