How to block youtube and enable Firewall visibility in aruba 3200 controller?
Hello guys, I am new in Aruba can anyone teach me to block youtube and p2p sites in aruba 3200? Also I can't enable the firewall visibility, do I need another license for that?
Thanks in advance!!
Re: How to block youtube and enable Firewall visibility in aruba 3200 controller?
You would need a 7 series controller to reliably block applications.
Tim
Tim Cappalli | Aruba Security
Aruba
AppRF functionality for the 3000 series controller is visibility only (see Colin's post below regarding 3200 vs. 3200XM).  You can only enforce policy (ie. block) on the next generation controllers, 7000 and 7200 series.
You'll need the PEFNG (Policy Enforcement Firewall) license for any role/firewall functionality regardless.
ACCX | ACDX | ACMX
The link here:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/firewall_visibility.htm?Highlight=firewall-visibility says what devices you can enable firewall-visibility on.  The 3200 is not included unfortunately.
Colin Joseph
Aruba Customer Engineering
I got this error message when I entered the command for firewall visibility.
That is because it is not supported on the 3000.  Please see my post above.
Colin Joseph
Yes it's not supported. Do you have any suggestions how to control these abusive users?bec. they are slowing our connection. I can't block them bec. they are our guests.
Apologies for the noob question, I'm really new in this.
Thanks!
you could see if you could apply a bandwidth limitation on there role.
