How to check if ClearPass joined a domain
Hi gurus,
I wonder if there is anyway to check if ClearPass joined a domain correctly, without leaving and joining the domain again. This is my situation, Event Viewer shows a problem with the domain:
But I can see ClearPass is joined to the domain:
But I don't know if the information of the last screenshot is only when ClearPass joined the domain the first time and not currently. How can I check it without leaving the domain?
Thanks in advance,
Julián
Re: How to check if ClearPass joined a domain
Looks like you are having issues with the domain process
You are running a very old code and it is no longer supported by Aruba , you should consider upgrading to the latest 6.7.x
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor,
Ok, and thanks for the advice about the code, I didn't know is no longer supported.
Julián
+1 on the ClearPass version. Make sure you are running up to date ClearPass software.
On the domain join check, you can do that on the CLI with the ad testjoin command:
[appadmin@cppm-nl]# ad testjoin NL
Join is OK
Where NL is the NETBIOS name of my domain.
Hi Herman,
That's exactly what I was looking for, many thanks!
Julián
