How to configure Aruba AP 93 with Aruba 3200 Controller
Dear Support,
                           I would like to ask how to configure Aruba AP 93 with Aruba 3200 Controller.
Frequent Contributor II
Re: How to configure Aruba AP 93 with Aruba 3200 Controller
What would you like to configure?
Make sure that the AP are connected with the Controller and you should be able to put it in an AP group with your configuration
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
