How to configure Onguard for Linux using the disolvable agent?
I need some help finding a "use case" document to implement Onguard dissolvable agent for Linux RHEL6.
Can someone steer me to such a document as a I just cannot locate one other than the document that says Linux is supported for onguard for certain features. (http://www.arubanetworks.com/pdf/products/DS_ClearPass_OnGuard.pdf)
Ken
Re: How to configure Onguard for Linux using the disolvable agent?
What NAS device are you using ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
