Contributor I
How to connect to clearpass on FTP protocol?
I want to log into Clearpass internal files but I can not log into it using FTP or SCP how can I do so?
Re: How to connect to clearpass on FTP protocol?
This is not currently possible.
Tim
Tim Cappalli | Aruba Security
Contributor I
ok how to log into clearpass as root to view folders and so on
You can't. It's a hardened appliance. If you are having issues, open a TAC case and they can access the root file system.
Moderator
We do not provide access to the shell of CPPM.
Best Regards
-d
ClearPass Product Manager
