How to create a 802.1X service for IP Phones and printers
HI,
I want to create a 802.1X service to check the device from the static endpoint list and allow VLAN as per the device type like:
IP Phone –VLAN10
Printer--VLAN20
Please help.
PRASANTH.
Re: How to create a 802.1X service for IP Phones and printers
Add devices to static hosts list group
Then in the enforcement policy create the following rule:
Connection > MAC address > Belongs to group ( static hosts list group) -----send VLAN 20 profile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
As per your suggestion, if I create a enforcement policy like
All the device MAC address added in the static hosts list will get a VLAN 20, here I want to assign VLAN according to the decive type like IP phone or Printer without doing the profiling.​​​​​
In order for CPPM to determine the type of device you will need to do profiling .
Are these devices on wired or attached to an Aruba AP ?
Thank you
Victor Fabian
Is it not possible to assign different enforcement policy without doing profiling?
If you were doing 802.1x then yes it would be possible without profiling, you could match on some element of the EAPoL exchange (MS-CHAP username, cert CN etc).  You are saying you want to use just a static endpoint so no two way communication with the phone or printer, therefore device profiling is the only way to glean information about the client device.
You can assign different enforcement policies if you use the static host lists by making a Printer group and IP Phone group but you cant make decision based on the type of device since CPPM doesnt have that information in the endpoint database
Thank you
Victor Fabian
You can do something like this:
Thank you
Victor Fabian
I have tried configuring the service authentication as follows:
Authentication type: MAC
Authentication Source: Static Host List
But I am getting the below error:
MAC_AUTH: No password in request. Not attempting MAC authentication
Cannot select appropriate authentication method
What is the network device you're using? You need to configure it to send the MAC address as the username and password.
Tim
Tim Cappalli | Aruba Security
