Occasional Contributor I
How to generate Evaluation License for CPPM on a VM
I have ClearPass Policy Manager model number CP-SW-EVAL installed on a virtual server.  How do I generate a certificate for a trial license key?  I do not see the CP-SW-EVAL system part number on the LMS.
Thank you,
Phil
Re: How to generate Evaluation License for CPPM on a VM
You need to work with your partner or Aruba SE.
Tim Cappalli | Aruba Security
Thank you, I have a call out to my Aruba SE.
