Frequent Contributor I
How to limit user sessions using Clear pass 6.6.x
Hi All,
How to limit user sessions using Clear pass 6.6.x as using the below url it does not work that is
in the fourth Screenshot of the url  "Database name tipsLogDb" says wrong
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-limit-simultaneous-active-sessions-from-a-given-user/ta-p/186556
Re: How to limit user sessions using Clear pass 6.6.x
Please use the more up-to-date method here:   http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-deny-access-for-authentication-request-based-on-session/ta-p/183304
Hi Colin,
               Thanks for the response. currently we are using the solution as per the URL posted and we are planning to upgrade  6.6.o or 6.6.1. so when tested to try same on 6.6.0 it fails so i am sure if we upgrade from 6.5.x to 6.6.0 it fail for sure. So trying  to check precise variable or parameter as mentioned to move forward
Are you using the old method, or the new method? The older one should not be used for newer installations.
We are using old method which is deployed already and running fine. Now customer planning to upgrade the clear pass 6.6.x. Once we upgrade i think old procedure will not work as database name does not match "tipsLogDb" in 6.6.0.
Is there way to tune the old method to work after upgrading to 6.6.x?
