How to login to cppm using winscp and required default credentials
Dear All,
How to login to cppm using winscp and required default credentials.
regards.
Re: How to login to cppm using winscp and required default credentials
What are you trying to do?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
want to load custom image to galaria skin path for CPPM guest.
You cannot SCP to ClearPass.
Sent from Nine<>
Tim Cappalli | Aruba Security
Under Guest, use the Content manager.
Sent from Nine<>
Hi, uploaded the custom image but there is no luck even after added the path.
This is all I did to have my 3 jpegs rotate on the front page.  I put the following in the BackGround Image Settings of the Galleria Plugin after I uploaded them to the public root of the content manager:
{literal}
<script src="external/galleria/js/jquery.backstretch.min.js"></script>
<script>
$.backstretch([
"public/myjpeg1.jpg",
"public/myjpeg2.jpg",
"public/myjpeg3.jpg",
], {duration: 3000, fade: 750});
</script>
{/literal}
