How to make a difference between smartphonesand tablets?
I was looking on the profiler and it divide it in smartdevice and computer or unkown
The problem is that how do i differenciate between smartphone and a tablet?
The tablets should be allowed but smarphones should not be allowed.  Is this possible for the clearpass to differenciate if its a tablet or if its a smarphone???
Cheers
Carlos
Alternetworks Corp
Re: How to make a difference between smartphonesand tablets?
You would either need to rely on "Device Name" or use the fingerprint data from the controller.
For the fingerprint data, see my post below. You can use similar logic to target tablets.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Tip-Using-IF-MAP-fingerprints-to-identify-legacy-devices/m-p/156396/highlight/true#M11549
Tim Cappalli | Aruba Security
