Contributor I
How to print many username and password guest accounts from receptionist view in just only one click
Hi friends,
I want to print many username and password guest accounts from receptionist view just doing only one click but I can't do it at this moment. The only possibility is printing one by one, as you can see in the attached images (guest portal screenshots), which it isn't an option to this role because usually there are a lot of people in front of them claiming and waiting for their credentials.
Does anyone know how to do this? In lack of that unless a suggestion to look into.
Thanks in advance.
Re: How to print many username and password guest accounts from receptionist view in just only one c
ClearPass supports multiple accounts print, immediately after the accounts creation or  after editing the accounts.
It looks like you are creating bulk accounts, you can either print ths accounts in one click at the time of creation or select multiple accounts that need to be printed under "Manage Multiple Accounts" and make a simple edit and Print the accounts together.
You may need to allow access to  "Manage Mulitple Accounts" for the Receptionist operator under Administration >> Operator Logins >> Profiles >> Receptionist >> Edit Multiple Guest Accounts.
Thank you,
Saravanan Rajagopal
**Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the post.
Contributor I
Thanks. I know that option but I don't want allow the receptionist to manage the accounts; it's a security reason. Is there any option?
[cid:image001.jpg@01D16024.886ABA00]
[cid:image002.jpg@01D16024.886ABA00]
José Antonio Lázaro Lázaro
Consultant
IT Communications Architecture Solutions
CCIE #9509
C/ Teide, 4 - 1ª planta
E. lazaro@unitronics.es | www.unitronics.es
T. Fijo +34 902 107 670
T. mobile +34 639 767 559 Vídeo +34 916 590 899
Aviso Legal | Follow us:
[cid:image005.png@01D16024.886ABA00] [cid:image006.png@01D16024.886ABA00] [cid:image007.png@01D16024.886ABA00] [cid:image008.png@01D16024.886ABA00][cid:image009.png@01D16024.886ABA00]
