Occasional Contributor I
How to remove Mandatory CPPM Device Attribute?
Hi, folks.
I was doing some testing and added a custom Device attribute. After adding the attribute, CPPM appears to have automatically added that attribute to every NAD in the database. I can't remove the value from the NADs (I assume because I marked it as Mandatory), so in turn, I can't remove the attribute because it's referenced by the devices.
Can anyone offer some advice on how to clean this up?
