- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
09-28-2016 01:26 PM - edited 09-28-2016 01:29 PM
I am trying to create a profile for Chromebooks but they do not seem to return the attribute for Chrome OS as I expect.
I receive this Alert on failure:
Policy server | Failed to get value for attributes=[Category, Device Name] |
RADIUS | [Endpoints Repository] - localhost: User not found. Applied 'Reject' profile |
The Role mapping looks like this:
(Authorization:[Endpoints Repository]:Device Name CONTAINS Chrome OS)
Profiling is enabled on the service.
Is there a way to classify Chromebooks so I can apply a role to them?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: How to role map chromebooks?
09-28-2016 02:09 PM
Do you add the ClearPass server as a DHCP relay under the data VLAN you are expecting to see the chrome devices ?
Get Outlook for iOS
Victor Fabian
Lead Mobility Architect @WEI
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-29-2016 06:50 AM
Yes Company Owned
Yes DHCP helper set in the scope for that VLAN on the controller to Clearpass.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-29-2016 06:57 AM - edited 09-29-2016 07:03 AM
In order for ClearPass to obtain the profile information the device needs to be able to obtain an IP address first.
You can use the profiler option in your service and if the device is not profiled (Endpoint DB) then you can place the device in a (temporary VLAN with a session timeout) just to allow the device to get an IP address and Clearpass is able to get the profile information.
The other option is to use the google admin console as an MDM solution to grab all the chromebooks currently managed through google admin console and dumps it in the endpoint database
http://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.5.3/Content/PriorNew/OldNew_MDM.htm
https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Handling-Chromebooks/m-p/261849
Get Outlook for iOS
Victor Fabian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-29-2016 07:06 AM
I see that makes a lot of sense. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
