How to terminate session for fortinet wireless user to complete health check
Hi
I have a fortinet wireless controller  and want to grant users access per to thier authentication and posture (healthy) check.
So I created the required services but I stuck in terminate-session action which required in the WEBAUTH (Agent healthcheck) service, as there is no terminate-session action available for fortinet.
So how to force the wireless users to terminate their sessions after the healthy-check
(I dont want to use bounce-agent action beacuse it causes the user to connect to other wireless network after the agent bounces).
Mahmoud
Mahmoud
Re: How to terminate session for fortinet wireless user to complete health check
Does your Fortinet controller support RFC 3576?
Tim Cappalli | Aruba Security
Hi
I am not sure. Will check for this.
But what is the procedure in both cases?
Mahmoud
Sent from Samsung Mobile
Mahmoud
If it does, you'll need to find out whether it's a standard DM/CoA format.
If it doesn't, you'll need to use the agent bounce.
Hi
So if it supports CoA, then can I use the RADIUS:IETF attributes to terminate the session?
As I didnt find such terminate attribute.
Mahmoud
Mahmoud
You can try using the generic IETF one, however they may require additional
attributes.
