How to test Aruba ClearPass' connection to AD via CLI?
Hello
How can I test Aruba ClearPass' connection to AD via CLI? For example I would like to ensure CPPM can authenticate a user, I believe the command "ad auth" will work for me but I am unsure how to use it.
Thanks!
Moderator
Re: How to test Aruba ClearPass' connection to AD via CLI?
Page 478 of the Uuer Guide
Best Regards
-d
Snr Tech Marketing Engineer - ClearPass
