Occasional Contributor I
How to use Clearpass as captive portal and MAC caching
The configuration for guest access using a captive portal and use MAC caching can be a tricky tasks. I have tried to write it down in a how to guide and I hope it can help others not spending hours or even days to figure out how it works with all the settings for this and that ;-)
Bo Nielsen
Re: How to use Clearpass as captive portal and MAC caching
Please use the ClearPass wizard under Configuration > Start Here > Guest Authentication with Mac Caching
Thank you
Victor Fabian
Lead Mobility Architect @WEI
