How to use custom form to generate guest-users?
we currently use the Captive Portal of the controller with a specific user called "guest-admin" to generate user accounts. This works fine so far.
But i think about integrating the form into our portal-system (dokuwiki) as a simple form, sending the requested parameters to the Controllers-API. Is this possible?
