Howto: How to obtain management access to Instant using ClearPass
In order to do this I am using IAP OS 4.0.0.4 and ClearPass 6.2.5
First add the ClearPass Server
You can use 3 different authentication options :
I decided to use Radius Server with Internal auth as fallback
Create an Radius Generic service and use the IP address of your Virtual Controller as the NAD IP address for the service rule
Select PAP as the authentication method and pick the authentication source of your choice , in this case I selected AD for authentication and authorization
I have created a role mapping that tags any user that belongs to the HOME-PRIVILEGE-GROUP AD group and then allowing this group to have admin access
Thank you
Victor Fabian
Lead Mobility Architect @WEI
