Frequent Contributor II
I can not open clearpass web UI ?
I have suddenly faceing a strange issue in being able to log into clearpass and I have the clearpass giving issue as the attached.
Re: I can not open clearpass web UI ?
Run this command from CLI and see if the web service is running:
[appadmin@CPPM-1]# service status cpass-admin-server
Admin server [ cpass-admin-server ] is running
If not you can restart it using this command:
service restart cpass-admin-server
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I Already did this and I also did start command on this service and it is doing the same
How are you access the GUI, directly via the IP or via a VPN or similiar? I've seen issues if the CPPM is behind a NAT address sometimes the URL re-direct to the GUI doesn't always work correctly.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
