Frequent Contributor II
I had a problem when I Install clearpass
I try to deploy clearpass OVF
But There is error . who know how to solve this problem
Aruba
Re: I had a problem when I Install clearpass
You need to add the required hard drive. Please read the vm install guide and it will take you step by step. You also need to make sure you allocate the correct memory and cores.
Thank You,
Troy
  • 8 Virtual CPUs
  • Disk space:
    • 500 GB disk space required for existing deployments (upgrading from 6.2.6, 6.3.6, or 6.4.x)
    • 1000 GB disk space recommended for new deployments
  • 8 GB RAM
  • 2 Gigabit virtual switched ports
I deploy OVF following this spec but it still have error
Aruba
Per your screenshot you did not add the hard drive.
Thank You,
Troy
Is it Hard disk ?? or not
Regular Contributor II
You have to add another hard disk
Aruba
You are not suppose to modify the default drive. You will need to delete the VM and redeploy. On page 6 of the install guide it clearly states you need to add an additional drive. .
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=16490
Thank You,
Troy
Judging from the last screenshot, you deleted SCSI 0:0. This disk is 20GB and needs to remain permanently. It is the install and boot disk. You did add the additional SCSI 0:1 disk, but deleting the SCSI 0:0 disk will not work.
Zach Jennings
