Frequent Contributor II
I have a clear pass Captive Portal Issue ?
I have configured a captive portal on the controller and workd fine and after that I have created a self register page and I added the URL of it to the captive portal profile but It keep redirect ro controller page not clearpass guest page keep redirecting to (Securelogin)
Re: I have a clear pass Captive Portal Issue ?
Did you add your ClearPass servers to the white list in your captive portal profile?
Tim Cappalli | Aruba Security
Hi Tim,
what do you mean by whitelist in this situation?
Adding your ClearPass servers to the captive portal whitelist allows 443 and 80 traffic in a captive portal redirect which is required for this to work.
You can also manually create an ACL allowing the traffic.
Yes I have did this for sure
Is the ACL above your captive redirect ACL?
I have permited HTTP-SVC and HTTPS-SVC in ACL and add the IP of CPPM in host field
Please run:
show rights <logni-role-name>
